Removing window tinting
Old Jun 4, 2013 | 05:41 PM
GentleGiant's Avatar
Default Removing window tinting
My stock window tinting is scratched up from my dog. How do you remove it to get it redone?
Old Jun 4, 2013 | 05:55 PM
fultonromero12's Avatar
It's a b**ch!!! I have seen it done but I depends on how long the tint has been on there. I have seen some tint remover spray. You peel up a corner then spray under it as you pull the tint off. Next you have to wipe the remaining glue off the window. How bad are the scratches?I would consider permanent marker is they are relatively small.good luck
Sent from my iPad using JK-Forum
Old Jun 4, 2013 | 05:59 PM
eclipse3319's Avatar
Flat razor blade, hair dryer or heat gun, and some sort of windex goo gone combo heat from the outside of the window and use the razor to start a corner, once you get it going just use your fingers to pull it off in one piece, I do this for work every so often
Old Jun 4, 2013 | 06:15 PM
MojaveJK's Avatar
Ya depends if it wasn't on long usually a razor blade will work good, will have a slight stink to it doesn't always happen, get some windex and clean the window using the razor blade as it'll clean everything off!
Old Jun 4, 2013 | 06:32 PM
Trauma's Avatar
I was under the impression that the stock tints in the rear were actually tinted glass?
Anyway, what I did when I bought my first car (used piece of crap) that had a bubbled rear tint was go to CVS and get a bottle of ammonia. Its like $1.50 for an entire jug of it.
Pour some in a spray bottle and on a hot sunny day, spritz it on the window and let it soak in. Do this a couple times and let it really soak in, after that peel it off. Use steel wool (0000) to scrape the remainder off.
Old Jun 4, 2013 | 06:38 PM
MojaveJK's Avatar
The back ones are right into the window.. Just thought of that. If its stock it's not coming off unless the dealer decided to put tint actually on..
Old Jun 4, 2013 | 06:40 PM
Trauma's Avatar
Yea, thats what I thought.
Front tints are illegal here for any actual amount of tint so I don't believe dealers install them I don't know about other states. But the windows of the hardtop and rear of a JKU you can't untint.
Old Jun 4, 2013 | 06:41 PM
MojaveJK's Avatar
Nope and ya maybe in his state it's legal to have the front window done.. Or maybe he bought one that was already clear. And had them do it maybe? Odd but stranger things have happens
Old Jun 4, 2013 | 10:04 PM
gregaf3's Avatar
Save yourself some time and use a garment steamer and a razor. No chemicals needed.
Old Jun 5, 2013 | 02:55 AM
FDHog's Avatar
Interior of my daughters car got flooded. Kept draining the water out and after about a month, the rear tints just pulled right off. No glue left and no. Scraping needed. Moisture will definitely do it.
