Replacement tie rod?
I need to get a new replacement tie rod for my JKU.
I don't think I need the heavy duty 1 ton tie rods. I really don't want to drill out the spindle. They would probably last forever though. I found a Moog brand and a Crown brand. The moog is $170 ans the crown is $100. I don't mind to spend the extra money if its worth it. The moog does have grease zerks and the crown does not. Which would be the better choice? https://cimg3.ibsrv.net/gimg/www.jk-...c366b49cbe.jpg https://cimg6.ibsrv.net/gimg/www.jk-...8043e7afae.jpg |
if you ar enot in the water and mud a lot then the non grease one is fine.
I bought the Moog one due to lifetime warranty |
Originally Posted by Seizer
(Post 4331693)
I bought the Moog one due to lifetime warranty I went Ruff Stuff and it isn't "ruff" enough for me. I also managed to put a kink in it. |
Do you have or are you considering to go with larger tires in the future?
If not then either of those will do. If you are, then you may want to consider the Ruff Stuff tie rod. It's a similar price as the ones you're looking at, but is a stronger 1 ton which will help provide a more solid steering experience if you go with larger tires. It's not bullet proof like Karl has experienced, but for a similar price as the stock size options, it is beefier than either of those options you're looking at and does not need drilling of the knuckles to install. Also if you hate rust like I do....then the Ruff stuff also comes unpainted and you'll want to put a coat of good rattle can and some clear coat on it to protect the finish. If you're into the bashing it on tree logs and/or rocks, then you'll want to look at the aluminum or chromoly options out there where the price goes up considerably. SteerSmarts Yeti HD are nice in this arena. |
Originally Posted by Rednroll
(Post 4331705)
I didn't have to drill my knuckle (2010) nor did my friend (2015 rubi).
You should only have to drill if you do a drag link flip, then there is drilling involved for the drag link on the knuckle side.
| All times are GMT -8. The time now is 06:54 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
