Roll Bar Mounted Cargo Rack
http://project-jk.com/jeep-jk-write-...ler-cargo-nack
You misssspelled the last word in your subject line.
I saw something over at AEV on a roll bar mounted roof rack...but Im not sure if it mounts through the top to the roll bar or if it can be used independently from the top. Late summer release I believe.
I found a plastic tray (the on in the pictures) cheap.
I had some heavy duty L brackets from something, don't remember what. I drilled through the wheel well and the slit the carpet to hid it. They are about 5" to 6" long and 4" or 5" wide. Then I drilled a hole in the tray and used some flat trailer brackets I had to secure it to the bracket. I used a wing nut to allow me to take it out as needed. Then the brackets give me other secure tie down points if I need it.
I will try and post some pics.
