Rubicon 2wd Swaybar disconnect??
Any one out there figure out how to get the sway bar disconnect to
work in 2wd?PLEASE SHARE!!!
I would love to get rid of the side to side head toss on uneven fire roads that do not require
4wd......and in a lot of situations in 2wd if I could just get some more flex I would not even need 4wd.
OR IF ANY ONE HAS ACCES TO THE SERVICE MANUAL SCHEMATICS SEND THEM MY WAY AND I WILL GET ER' DONE ASAP!!
Thanks BWR
Thanks BWR
Have you tried to shift to 4hi, press the disconnect button, and once it disconnects shift back to 2 hi..
Although the system will attempt to reconnect if you go over 18mph even in 4hi.
I don't have the disconnects but that works for turning the ESP full off in 4hi it stays off when you shift to 2hi.
