Safe jack points besides axle?
It's probably not recommended, but if I had no other choice i would. Assuming you are talking about a hi-lift? Most concerning part about the sliders is there is nothing keeping the jack from sliding on the slider while loaded.
From the looks of that it either A)wont reach the sliders. or B)wont fit under the axle as an assembly. Thats just from looking at it and based on the 3ton stands I have myself. I wouldn't worry too much myself about unscrewing at, as long as the wheels are on the jeep is only going so far, bottle jacks can be let down pretty slowly..
looks pretty interesting, haven't seen one of those before.
Use the frame, and use those short pieces of 2x6 you should keep in your vehicle in case you get stuck to raise it up. My pieces of 2x6 saw a ton of use for other vehicles during this recent blizzard we had.
To answer your original question... I have lifted the jeep by the rubi rails, although it was with a high-lift.
No problem lifting a tire off the ground, but it bent the rail bracket slightly, so now it's running at a slight angle along the body instead of exactly parallel.
JK-Forum Founder
if you jack from the frame or rocker guards, you will need to lift up the body of your jeep high enough to unload the weight off the coil before your tire starts coming up off the ground. this is dangerous and totally unnecessary. when changing a tire, you should ALWAYS try to jack from the axle (pumpkin or base of control arm joints are good locations) and not the body. this will require a minimal amount of lift in order to get your tire off the ground and is much safer.
My concern has been to damage the pumppkin or axles. The rear is in the middle, so i guess i can jack both backs up at once? The pumpkin can handle the weight?
How about the front. If using the axles, do i get closer to the hub or the pumpkin for minimal stress?
To help the OP, I have lifted my jeep by the sliders a few times. It will work but may bend the mounting brakets. It can be adjusted but becomes nasty. i would use the rails only when i had to.
