idtpes |
05-18-2019 07:50 PM |
Serpentine Belt jumping and very loud clicking noise
Hello, I have a 2008 Wrangler Sahara and I have a very loud clicking noise that is occurring in the front part of the engine. I thought it was the power steering pump that was the cause because there was a what I thought an unusual amount of play or a bit of a wobble in the pulley shaft when I manually turned the pulley. Turns out after I replaced the power steering pump that was not the cause. Also, the if I watch the belt tensioner (which I have also replaced as I thought it might be a bad bearing), it is flexing quite a bit in sync with the clicking noise. Also, the belt works it way off outward on both the power steering pulley and the pulley located next to the alternator. I am on my second belt tensioner and belt since I thought the tension was defective. If I remove the belt completely, the noise is gone. When I reinstall the belt, the noise immediately returns. Maybe one of the impellers in the water pump broke off and is rattling around? I haven't had any over heating problems, but then again I am not driving it around since this rattling/clicking noise started. Any thoughts on what else could be the cause?
