Should This concern me?
Old Jul 16, 2011 | 02:32 PM
gludo's Avatar
Default Should This concern me?
I was just wondering if this should concern me. It was loose , so I tightened it up.
Old Jul 16, 2011 | 02:34 PM
JayhawkJeep's Avatar
Veteran: Navy
Are they stock or aftermarket?
Old Jul 16, 2011 | 02:39 PM
gludo's Avatar
Stock. I have the AEV 3.5" premium lift, and no other suspension mods.
Old Jul 16, 2011 | 03:05 PM
AK4Dave's Avatar
I think if it was me I'd have the hole welded up and re drill it the right size again. Guess I should go check mine....
Old Jul 16, 2011 | 03:14 PM
33 williys 77's Avatar
And then washers with the right I.D welded on also ( more meat )
these jeeps are really tin cans.
Old Jul 16, 2011 | 03:37 PM
nthinuf's Avatar
Why would a slipped Cam Bolt concern you? Not like your caster changed or anything...
Guess that's why aev stopped selling cams with their lifts and went to the ca brackets. Set your caster where you want it, keep it tight, and hope it doesn't slip again. Or tack weld it in place. Or remove them, have the holes welded back up, and add adjustable ca's or the drop brackets.
