Shuddering when braking?
Old Aug 26, 2011 | 03:19 PM
Gypsy's Avatar
My Jeep has always done this a bit but it has happened a couple times wickedly in the last couple days and it is scary. When I am going around a sharp corner and braking or hit a bump when braking the Jeep shudders and I feel like the Jeep lets up on the brake and I'm losing control.
Is it the EBS? ESP? Is it the DW? I got new tires recently - wider but not bigger - do i meed the Jeep flashed? I can regain control pretty quickly but those few seconds suck.
Anything I can look at or do to correct this or is it just a Jeep thing?
Old Aug 26, 2011 | 05:50 PM
Vin's Avatar
Vin
Sounds like the ESP. Stop driving like an American!
Old Aug 26, 2011 | 05:56 PM
f2fast4u's Avatar
How many miles on your front brake pads?
Old Aug 27, 2011 | 07:01 AM
kik's Avatar
kik
Maybe you're pushing it too hard. Maybe you have a warped rotor. You might have worn pads. You could have a bent rim. It could be any number of things unfortunately.
Old Aug 30, 2011 | 08:33 PM
f2fast4u's Avatar
So, still problem?
Old Sep 3, 2011 | 07:15 AM
Pepperdine's Avatar
This stared happening to me right after I got my lift, Wheels & Tires. The ESP light flashes and the brakes shutter bigtime when slowing and turning mostly from a freeway off ramp. In the rain I really think this could be dangerous. Not sure what to do.
Old Sep 3, 2011 | 07:21 AM
Deere_Jeep's Avatar
Did you recenter steering wheel? How about a programmer like AEV Procal?
Old Sep 3, 2011 | 07:26 AM
BrowniesJK's Avatar
Your steering wheel needs to be centered. If its not you can fix very easily. Loosen the two bolts on the Dranglink adjustment and turn it until the wheel is centered. Tighten the bolts and your done. This might take a few tries to get it perfect.
Old Sep 3, 2011 | 05:19 PM
Gypsy's Avatar
Yup, still a problem and pepperdine has described exactly what is going on generally on off ramps or when I have to pull the wheel to the extreme on one side or the other. It is scary!
I will try re-centering and any other suggestions you all have. Thank you for responding everyone!!
Oh, and front brake pads were done not so long ago. And I drive fast but I'm not a maniac. ;-). This happened today at 30kms...
Old Sep 3, 2011 | 06:38 PM
BrowniesJK's Avatar
Is it a pulsating feeling like your ABS has kicked in?
If so I'm sure it's related to your steering wheel Alighnment. I have 4" lift and I'm on 37's. I can go as fast as I feel safe around any off ramp. The wheel doesn't need to be off by much. Good luck...
