So I'm annoyed!
So I'm annoyed!(plug wire question)
....should I be?
I'm getting surgery on my hand, so theres no way I could do my plugs/wires on the passenger side of my '07 3.8l
Took it in to get that side done. When I came home I decided to have a look, and they routed the wires ON TOP/ACROSS the intake manifold instead of behind the way the factory wires were.
Aside from looking bad, is there a problem with this? I guess beggers cant be choosers, but it just seems lazy.
So I called today and said I was concerned about the wire routing and he said there is less heat across the intake manifold than near the exhaust at the backside.
Grrr. I think it will be fine until my hand is better and Ill just do it myself.
The hood is closed so I cant see it but I still think about it!
I doubt theres a bulletin, but I think there is less heat than behind the motor near the exhaust. That said, since the plug/wire change my idle has been rough and my radio has interference/static that wasnt there previously. Im not sure if that is an effect of routing or just a bad wire. I used factory plugs (champion double platinum) and AC DELCO wires.
Sounds like they were just lazy, and yes I'd be annoyed as hell. They'd fix it after they got an earfull, then once they were done doing it right they'd get another earfull.
Protect your hands guys. Not being able to things yourself sucks. :(
Always amazing how fragile our bodies are and how little it takes to incapacitate you sometimes.
So you never went back and asked them to route those properly? I think I would have.
I would have went back myself and had them do it the right way.
On another note (not to take away from your issue) but I so much want to return mine to factory that I would like to know the part numbers of the wire trays and other plastic pieces that go on the wires. I broke a few of them when I did my wires. Anyone know the part numbers?
