Soft Top
I need help on repairing my soft top. On the pass. side the top frame flaps when driving Fwy speed and surface st. speed. I'm affrad the top will go fling off. How can I can I fix this problem without braking the bank (my bank)?
First you need to identify the source of the problem and give a little more background on the top. Are the front two latches done up? Is it the early style that tucks in to the door surrounds or the later style with the cable and clip (no tuck)? Is there even a door surround there for the top to attach to??
Determine where the fault is and then go from there. Soft tops can be bought used for cheap enough and it shouldn't be too tough to source door surrounds.
Sent from my Droid4 and Jkfreaks.com
