Soft Top Brackets with a Hard Top?
My JK has both a soft top and hard top; the soft top is currently installed. There are two small, black, metal brackets that join the soft top bows to the roll bars....Do these absolutely need to be removed when I go to install my hard top, or can I just leave them there after removing the bows? Yeah, I'm lazy.
Jeep recommends removing them due to rear occupant safety. Without a soft top attached they can be dangerous in an accident. I remove mine and reinstall every year. It's literally less than 2 minutes per side.
I could see on a 2 door where you might get hung up on them when trying to exit the rear seats if you don't have the soft top bars attached to it.
BTW those things are a pain to take off if you have the hard top installed. My JK only came with a hard top and when I purchased a used soft top, the guy didn't remove those brackets before he put the hard top on. I tried taking them off with the hard top on because the guy didn't want (or know) how to remove the hard top. I ended up just saying screw it and bought new ones when I got home instead of trying to remove his.
