Soft top latch rattle
Has anyone found a solution to the soft top latches clanking when in the sun rider position. I velcrowed them to the header bar, but just a little bit of bouncing or wind still causes them to clank. It is driving me nuts!
Originally Posted by jstin120
Not really looking forward to living with it...
I will come up with something and post the results.
i have the same issue when the top is folded down and i am on a bumpy road....i was thinking about trying these picnic tablecloth clamps and dipping them in rubber for grip.....i will let you know if it works this weekend.
I sprayed open gear lube from NAPA in all the hinge points then cleaned off the excess, RATTLE GONE !!!! It was the same lube I used to fix my steering cluck on my 2009 Limited by spraying the spline on the steering shaft. The grease gets sticky and gets rid of the metal on metal you hear from the latches. I tried to remove one and tried to bend in the bracket to make it tight what a bitch to get it back on, did not work... Try the open gear lube it works.. its simple and cheap...
