Squeal Underneath
Hi Everyone! I have a 2008 Jk and there is s high pitched squeal coming from underneath that changes with rpm's. It is barely noticeable at idle but will sound when I press the gas pedal. Engaging or disengaging the clutch makes no difference. Moving or sitting still makes no difference. I peaked underneath and saw a bit of smoke coming out near where the crank case is. I know I do have somewhat of an exhaust leak but it is not real new. We just went through a horrible cold spell. Any thoughts? The sound resembles a bearing going bad or s slipping belt. Thanks so much for any help!!
I recently had a squeal in my 2012. I was 100% sure it was a belt. Nope. Turns out it was the starter going bad. The starter was not fully retracting which allowed some small contact that resulted in the squeal. Other likely culprits to consider are the water pump and idler pulleys.
I think it's the water pump dying. Thanks for the info.
Rob |
Originally Posted by wideglide7777
(Post 4335426)
Rob https://www.oreillyauto.com/detail/b...thoscope&pos=1 |
Definitely getting one. Tx
(Post 4335426)
Rob |
