Steering components advice
What are your thought on these parts to replace stock tie rods ends, etc?
https://cimg7.ibsrv.net/gimg/www.jk-...4627acb94.jpeg |
Well, you're talking almost $200 to basically make a factory TR. You can make an aluminum TR with 1-ton ends for ~150, or even buy the Rought Stuff aluminum TR for about that cost, so buying AC Delco parts makes no sense. As far as the drag link, if you have a bad end and the factory DL is fine for your application, then that is what it is. I think the Moog end used to be a bit cheaper, closer to $50, but that was a while ago. Things may have changed since then. I used to have one I'd send you for the cost of shipping, but got tired of looking at that crap sitting around.
Never heard of that site, I'll check it out thank you
Sorry, it's been a while since i looked at these TRs and my figures are off. The Ruff Stuff one I could have sworn was around $250 but it's $295, and DIY version, which mind you is simply ordering the bar tapped and threaded as you need for the GM ends is around $200. Here is a link should you care to consider it -
https://www.jk-forum.com/forums/modi...ie-rod-346539/ You'd get a lot better TR that way, but if factory is suitable for you, you might be able to find a take off one for practically free. |
