JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Stock JK Tech (https://www.jk-forum.com/forums/stock-jk-tech-12/)
-   -   Steering wobbles or "hops" while turning (https://www.jk-forum.com/forums/stock-jk-tech-12/steering-wobbles-hops-while-turning-276185/)
fuffl May 28, 2013 03:18 PM
Well, I went wheeling last weekend and fear I've broken something. Trouble is, can't figure out exactly what.
Problem: The steering wobbles or "hops" when turning. It has to be a somewhat sharp turn like an intersection. Nothing happens driving down the road. When I say "hop", I mean it feels like my 76 Blazer with locking hubs when it's been left in 4wd. The problem is that I'm in 2H!
Any ideas on what could cause this would be greatly appreciated. I focused initial efforts on the wheels, brakes, and tie rods but those look solid.
EzK May 28, 2013 03:29 PM
Obvious idea here but is it possible that your shifter is messed up and its actually still in 4 high?
jtphoto JK May 28, 2013 08:30 PM
Axle u-joint(s) seizing up.
101gargoyles May 29, 2013 01:34 AM
X 2 Broken transfer case shift cable plastic linkage? At the transfer case end it won't trigger the 4WD light on the dash.
If so good news because it's like a 50 cent part.
iamspecialized May 29, 2013 04:03 AM
X2. I just had mine replaced last month and had the exact same issues as you described.
TheDirtman May 29, 2013 04:23 AM
Tire rub or u-joint would be my guess.
familytime May 29, 2013 05:19 AM
Axle u-joints
fuffl Jul 9, 2013 09:50 AM
Thanks for the tips guys. The transfer case checked out OK. Took it in to the dealer and they said the U-joints were fine. They were insistent that it was the stablizer and a ball joint. Replaced the joint and put in a Rancho stabilizer. The tug is still there and I just had my first experience with Death Wobble! Argh! Back in the shop again tomorrow. Hopefully they just replace the joints as I asked the first time:naw:
BigLow Jul 9, 2013 12:00 PM
Check your toe-in. You might have bent your tie rod (which is pretty damn common).
Pape Jul 9, 2013 01:47 PM
Got the same problem and it disappear by it self. I think it related to the u joint
© 2026 MH Sub I, LLC dba Internet Brands
