Stock tire carrier
Old Aug 30, 2007 | 12:58 PM
Jkmudder07's Avatar
Default Stock tire carrier
How much weight can that thing hold?
Old Aug 30, 2007 | 03:03 PM
rock342's Avatar
Not sure really....I've got a 35" BFG M/T on a 17x9 aluminum rim....no problems yet.
Old Aug 30, 2007 | 04:46 PM
FLyellowjk's Avatar
i think, i might be wrong... but i believe that the manual states the it can hold up to 50 LBS
Old Aug 30, 2007 | 04:49 PM
DeepSky's Avatar
Same here. I'm sure it weighs more than 50 pounds though
Old Aug 30, 2007 | 05:14 PM
Jkmudder07's Avatar
thats actually what i planned on having on it. Maybe there could be problems when off roading?.....hitting a hole to fast or something
Old Aug 30, 2007 | 07:41 PM
BigJerm's Avatar
i have my 35" with 16" rims on the tailgate and have done plenty of offroading with no issues yet
Old Aug 30, 2007 | 08:48 PM
drbeddow's Avatar
I have a 35 inch Micky Thompson Baja MTZ on a Procomp wheel , approximately 100lbs, on it and no problems so far. And as far as the 50lb weight limit, I weighed the stock one that was on it and it was 70lbs so that doesn't make sense.
Old Aug 30, 2007 | 09:17 PM
zcupa's Avatar
I have 35s and there use to be a 1 and 1/2 inch between bumper and tire, now the tire sits on the bumper and squeaks.
Old Aug 31, 2007 | 04:25 AM
Paul R's Avatar
From the 2007 Wrangler Owner's manual, page 353:
" If you have added aftermarket accessories to the spare tire mounted carrier, it cannot exceed a gross weight of 50 lbs (23 kg) including the weight of the spare tire."
As stated above, this does not make sense, as the stock spare weighs more than that.
Old Aug 31, 2007 | 04:33 AM
jeepsteve's Avatar
you wont have problems right away, but over time you will. i had a TJ with 33's on steel wheels on the tailgate that worked fine for a while but it eventually bent the tail gate.
