stuck in 4wd Lo
Old May 11, 2009 | 01:14 PM
gdeal's Avatar
Default stuck in 4wd Lo
my 08 rubicon UNlimited got stuck in 4wd Lo. took it to the dealer. they said they have to order a cable because it broke. they said it's an external cable that runs from the transfer case to the (I think they said axle? or maybe transmission). Anyway what would cause the cable to brake?
Old May 11, 2009 | 01:52 PM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
the ends have a cheap little plastic retainer, you arent the first and it seems like quiet a few have been having this problem lately check out these recent threads about it
https://www.jk-forum.com/forums/show...41#post1114641
https://www.jk-forum.com/forums/show...t=52121&page=3
Old May 11, 2009 | 01:53 PM
myklt8's Avatar
Usually it is not putting it into 4lo correctly
need to be rolling (under 5mph) in neutral and pull it into 4lo, it will go into gear with little effort.
Old May 11, 2009 | 04:04 PM
wintweedie's Avatar
Mine broke while at Moab for Easter Jeep Safari. I went Moab Off Road 4X4 to get it fixed. They said that they had seen 3 broken cables that week. They thought the cable end at the transfer case was to close to exhaust and was causing the plastic cable end to get hot making brittle and break.
They fixed my problem by welding a threaded bolt shaft to the transfer case shift lever and then welding another threaded bolt shaft to the end of the cable. Then threading a small hemi joint on the cable end. Then adjusted the hemi joint on the threaded rod for proper length put hemi joint on transfer case shift lever bolt and locked it down.
This should never break again.
Win T
Old May 11, 2009 | 04:09 PM
gdeal's Avatar
I would like to see Jeep come out with a never break again fix. There has got to be something better than plastic. at this point I would be happy to see a TSB out on this.
Old May 11, 2009 | 06:44 PM
berg's Avatar
Win T
Would love to see some photos of this
Old May 11, 2009 | 08:46 PM
1JK's*'s Avatar
Check out the first thread in post #2. There are pics of mine that broke after I got off the trail. I took it into the dealer today and they have to order the part. You can't buy just the end piece, you have to replace the whole cable.
Old May 11, 2009 | 08:53 PM
yetibear's Avatar
We don't want pictures of your nasty broken parts, we want pics of the mini hemi joint repair!
Win T
Old May 12, 2009 | 07:12 AM
Smopho's Avatar
The first time I tried 4 low in my new Rubi it did the same thing. The cable did not break, but it did come off of the transfer case sector shaft. The retaininer clip that holds the shift cable cleavis to the shaft was either missing, or had come off. You can reach up there (after the exhaust pipe cools off) and manually move the sector shaft back into 2wd so you can drive it home. I bought a new retainer clip from Tractor supply and put it on myself because the dealer wanted the vehicle for two days just to look at it. My Rubi was built in Oct of 2008. One thing I noticed is you have to put a 1/4 turn of twist on the shift cable cleavis to get it to line back up with the shaft. I don't know if that is normal, or not, but that twist puts a lot of side force and could force off the retainer clip.
Old May 12, 2009 | 07:13 AM
Smopho's Avatar
Tractor Supply is your friend for spare end clip retainers.
