Superchips Flashpaq question
Old Sep 14, 2012 | 08:23 AM
Brandt65's Avatar
Default Superchips Flashpaq question
If I disconnect my battery to install the cruise control, does anybody know if I would need to reflash the settings I have programmed into my Jeep, or will they still be set the way I have it after reconnecting the battery? Thanks.
Old Sep 14, 2012 | 11:11 AM
Ryan0260's Avatar
No you would have to un-install the tune and install the factory tune. You will be fine
Old Sep 15, 2012 | 03:51 AM
Brandt65's Avatar
I really was concerned if I would have to redo the changes I made for the wheel size. I made those changes as well as having it in offroad mode for the tpms system, and I run the 87 program. It was a pain getting the right size on the tires to get the speedo right, and I just needed to know if I would have to re-enter all that after having the battery disconnected while installing the cruise control. I'm only disconnecting it so I don't accidentally set off an air bag. Will my settings be there is I just disconnect the batter, do the install, then reconnect the battery and do nothing else? Thanks.
Old Sep 15, 2012 | 06:17 AM
JDanderson's Avatar
Yes all will be there, it reprograms the computer, so no worries I disconnect mine often when working on it
