| Seth |
Feb 8, 2008 05:07 PM |
They're not hard at all, you'll need a 10mil for the five screws under each plastic frame in the front, needle nose pliers to take the clips out the holes for the fenders, and a small crosstip screw driver to pop out the plastic rivets.
For the front flares, use the small crosstip to push in the center of the small rivets connecting the fender to the splash shield in the wheel well. Once that pops in, you can pull them out. Then starting at the front and rear of the fender, pull up. That will pull them off the plastic clips.
To remove the splash shield, you will have to pull down on it to pop out the six plastic push pins.
Next, disconnect the fender light. Then unscrew the five screws holding the plastic fender frame to the body. At that point, use the needle nose pliers to pinch together the plastic pieces that hold the fender clips to the body and pull them out of the holes. You can see the front clips the easiest, the rest you can do from feel.
It would probably be easier to connect the splash shield to the fender with the plastic rivets while its off the jeep. What I did, was replace the rivets with a nut and bolt.
After that, reinstall the plastic frame, pop the new fender with the splash shield already attached on, and push in the pins for the splash shield. After you reconnect the light, it should be done.
The back fenders don't have the plastic frame or a light, just the fender and splash sheild, but those are the same at the front, repeat what you did for the front. It probably took me as long to type out how to do it as it does for me to actually do it.
