Ticking Noise ... Help me identify!
Old Mar 25, 2016 | 02:50 PM
feroxjb's Avatar
Default Ticking Noise ... Help me identify!
Anyone have any idea what this ticking noise is? Maybe I'm just being paranoid because I recently took my Jeep top and doors off for the Spring and have become more aware of the sound.
Normal? Any idea?
https://www.youtube.com/watch?v=mabS-b33R8k
and the second one.. notice it increases/decreases with RPMs
https://www.youtube.com/watch?v=3dRbcG0WkT0 Thanks guys for any help you can provide!!
Old Mar 25, 2016 | 03:00 PM
themoneyshot's Avatar
A lot of the valves tick. Mine tick when I first start it but after the oil thickens it goes away. You can YouTube it and you'll find umpteen complaints.
Old Mar 25, 2016 | 03:01 PM
feroxjb's Avatar
Is it the valves though? It doesn't go away after driving. I just pulled into the parking space at the movies a few mins ago (5 miles away), and it's pretty loud.
Old Mar 25, 2016 | 05:37 PM
feroxjb's Avatar
According to this post, it was a timing chain making the noise.
https://www.youtube.com/watch?v=IzO2nP5VTTw
Old Mar 26, 2016 | 05:30 AM
silverfox82's Avatar
Normal? Any idea?
YouTube Link: https://www.youtube.com/watch?v=mabS-b33R8k
YouTube Link: https://www.youtube.com/watch?v=3dRbcG0WkT0
I have a 2010 jk that sounds identical to yours. I changed timing chain and oil pump thinking it was chain slap. I was sadly mistakin
Old Mar 26, 2016 | 05:33 AM
Normal? Any idea?
Does the ticking start after the engine gets to normal operating temp like mine??
Old Mar 26, 2016 | 06:15 PM
Ryan0260's Avatar
That doesn't sound real good. What oil are you using? I would definitely try a thicker oil like 5 or 10w30 and see if it quiets down.
Old Mar 26, 2016 | 08:13 PM
ronjenx's Avatar
I'm hearing about 5 ticks per second at idle. That sounds like how often a lifter gets an input from its cam lobe.
I have heard the same sound from a bad lifter, a worn cam lobe, and a broken rocker arm.
Listen at each valve cover and see if you can determine which side it's coming from.
Old Mar 26, 2016 | 08:37 PM
feroxjb's Avatar
So typically I use 5w20, but since I've taken my top and doors off for Spring and started becoming more aware of it, I decided to do a "Motor Flush" and changed the oil to synthetic 10w30, but it doesn't seem to have any noticeable effect.
The reason why I was thinking it was the timing chain, was based off that one youtube video that sounds almost identical to it. =\
I'm thinking of picking up a mechanics stethoscope to try and zone in on the noise.. it SEEMS like it's coming from the bottom end, which correlates with the timing chain.
Old Mar 26, 2016 | 08:38 PM
feroxjb's Avatar
Silverfox, did you ever figure out what the sound was or are you still ticking away?
