tires
I have questions about tire size and rims for a 2013 Jk unmodified(so far). I have a set of 18's with 265/70 Toyo A/T will they fit? Lug pattern is universal on rims
Really nobody?
Yes they should fit without rubbing, I ran my 285/70/17 duratracs for a couple days without a lift and there was no rubbing. The first picture is my tire compared to your tire, the second is the 285s without a lift on stock rims
http://img.tapatalk.com/d/13/12/15/5u6eve9u.jpghttp://img.tapatalk.com/d/13/12/15/anu4u8yp.jpg |
Re-reading it looks like you are more worried about the tire fitting the rim, the 285s fit the stock rim so your 265s should be fine
Originally Posted by trentrester
(Post 3784622)
BTW, pistol at 11pm and wake up to expect a respinse? Patience bud, practice some patience. I think people sleep at night. Just a guess..... ;) |
They fit fine on the rims and unless you have no backspacing or crazy negative backspace then they should fit the Jeep fine too.
Others nailed it though- your lack of clarity is why you didn't get an instant response. Sent from my DROID4 using Tapatalk |
Originally Posted by aircrew423
(Post 3784820)
Should 285 wide scratch a bit? |
Originally Posted by Breitling
(Post 3784869)
Originally Posted by jadmt
(Post 3784872)
I can say with 100% certainty on a 14 jku and a 14 jkur 285/70-17 toyo open country at2's will rub on the front sway bar and the air dam of the sport when mounted on stock rims and no spacers used. 1.5" spacers mitigated the problem completely. The sport has a 1.5" lift the rubi a 2" lift.
(Post 3784822)
