Tpms
Just curious, but what stops one from putting regular valve stems in their tires and removing the TPMS units and forgetting them all together? Is it that the tire stores will not mount a tire without the TPMS installed? I have often wondered about this as I think the things are a pain. I used to run my tires with the steel valve stems and never had a torn or ruined valve stem off road.
An annoying beeping every time you start the Jeep. Not to mention the light is always on. Just annoyances really.
They are really easy to remove from your old wheels if you have the means to break the bead on your tire.
Check out the AEV Protocal Tool. It shuts off the TPMS and does many other cool things including turning on daytime running lights , Speedo Re-cal, etc. WWW.AEV-CONVERSIONS.COM
SLIM
SLIM
