TPMS when changing wheels
I currently have an 08 Sahara with the stock 18's. When I buy new tires, I'm thinking about going to 17's or 16's. Can I just swap the current TPMS in the stock wheels to the new ones, or does something else need to be done, too?
The rebulild kit isn't what you need. Take it to discount tire if there is one in your area. They can put it on just about any wheel. If the sensor wont fit where the valve stem goes, we used to band them to the drop center of the wheel similar to the way ford did them, remove the valve core and install a regular valve stem into the wheel. Worked perfectly fine with no ride complaints.
Good to know. I don't think I have a discount tire around me, so I'll have to check with the local dealer. If I change wheels, it will probably just be to moabs so everything is still stock, but we'll see. I really like the MB72's.
