trackbar bracket, whats the fix
Hiya guys,
I discovered a bit of play in my front trackbar bracket, as shown in the video. I'm getting a little wandering when I'm hitting bumps, so how is everyone fixing this problem ? I know a couple of washers can be welded, so how long can I expect that fix to last...
Not sure if I can get hardened steel washers. If anyone can pipe in with a washer size,or another fix, that would be appreciated, cause I just put it back together without measuring,, dah,,
http://www.youtube.com/watch?v=U4EEfGfXQh8&list=UU9uP33teEPHDXwKH9HGjacQ&index=1&feature=plcp
You can use grade 8 washers, as they are hardened. The thicker the better. you can double them up also. make sure they fit your bolts nice and snug.
But I believe the best option is the bolt on track bars bracket. All the major players that make lifts have
them. I am planning on adding one when I get my lift. ounce of prevention sort of thing. I just got my 2012. I am learning that they have a whole different list of issues compared
to my TJ.
to my TJ.
Id skip the washers and go with new brackets. I added frame and axle side front and rear, beef up brackets. I've ripped off factory front and rear brackets before. Def worth the money to just add more bracing
I'll check out the vendors in Moab this year and see if they have any brackets with them, till then it's going to have to be washers I guess..
Thanks for the input guys !!
