Transfer case question
I changed the fluid in my transfer case for the first time yesterday. Everything went ok, but I'm wondering if I put the drain plugs in too tight. Do I need to get back under there and loosen them up or should it be ok?
Thanks, Phil |
Eh... how tight did ya make it? Torque spec is 15-21 Ft Lbs.
Project-JK.com - Jeep JK Wrangler Resource » Jeep JK Wrangler Torque Settings |
Pretty tight. I could still tighten more if I wanted to but it would take a little strength. I just used a regular ratchet and I'm not sure how to measure the torque.
Thanks, Phil |
Originally Posted by phil1031
(Post 4197767)
Thanks, Phil |
I will definitely get one for the next time I do it, but what about for now? I really don't want to take that skid plate off again but I don't want anything to get damaged either.
Thanks, Phil |
(Post 4197784)
Thanks, Phil its hard to say. one persons just right could be pretty weak or wayy to much or just right so there is no way for us to tell. I just snug mine up till they dont leak. |
Originally Posted by shabbernigdo
(Post 4197787)
I just snug mine up till they dont leak. Check it for leaks a couple times.... if it's not leaking, then let it be. |
Ok, I'll do that. Thanks for the help everyone!
| All times are GMT -8. The time now is 06:54 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
