Originally Posted by tgrt
(Post 314388)
Nintendo code. :rotflmao1:
To turn off ESP off forever: ABABABBBA START. |
Originally Posted by karnuvore
(Post 313938)
Sooooooooooooooo......
Would my description of what I hear be "normal" then? For instance, today, in sugar sand in my orange grove, I had a clicking metal on metal sound from my left front wheel as I was driving maybe 5 mph (in 4hi) and deliberately trying to get it stuck in some really sugary grove sand. Had the ESP off. I am honestly ignorant in this area...is that normal? I truly appreciate your input/opinion. Trust me, I would be incredibly happy to hear the noises my jeep is making when it is struggling - are normal. I would like to know that it is just my jeep saying "put me in 4Lo asshole.":mad: dave |
Sounds like Microsoft had their hands in the ESP system, kind of like automatic updates.
(Post 315188)
hehehe...you rock. Thanks. I went to the dealership today and they showed me the hold the ESP button for 5 secs. turn it OFF thing - went immediately into some groves, did so, and it ran fine.
thanks again. dave |
tried this this evening on a 07 unlimited x and it didn't work. Tried it in 2wd, 4hi and no success. I noticed the light turn on on the dash and then turn off after 10 seconds of holding the button but it didn't disable the ESP.
Originally Posted by Woods
(Post 314485)
SWEET! I want the damn ESP off permanently. |
NUMBER: 05-001-08
GROUP: Brakes DATE: January 18, 2008 SUBJECT: Electronic Stability Control Disable Feature For Modified 4WD Vehicles OVERVIEW: This bulletin involves selectively erasing and reprogramming the Anti-Lock Brake/Electronic Stability Module (ABS), the Cabin Control Node (CCN), and the Totally Integrated Power Module (TIPM) with new software. Once these modules have been reprogrammed (flashed), a sequence of steps will be required to disable or enable the vehicle Electronic Stability Program (ESP). MODELS: 2007 (JK) Wrangler NOTE: This bulletin applies to Four Wheel Drive (4WD) vehicles. DISCUSSION: Vehicles modified with larger tires and/or suspension lifts may experience early Electronic Stability Program (ESP) activations as compared to a non-modified production vehicle depending on lift size/height, tire size, suspension changes and/or driving habits. If early ESP activations are experienced while driving with a modified vehicle, the additional ability to permanently turn off ESP is available. This ESP permanently disable feature can be obtained once the ABS, CCN, and TIPM modules have been flashed / reprogrammed with the correct level of software, as described in the Repair Procedure. After completing reprogramming of the modules, an ignition switch, steering wheel and ESP button maneuver must be performed to permanently disable ESP and to turn off the functionality of the ESP switch. Once the ESP system is placed into permanent disable mode, the ESP Telltale will be illuminated in the instrument cluster, and the vehicle odometer will display a “ESP OFF” message. The ESP permanent disable feature DOES NOT disable the vehicle Anti-Lock Brakes (ABS) or the Brake Assist System (BAS), when the feature is implemented per this Service Bulletin Repair Procedure. Repeating the ESP permanent disable maneuver procedure will return the system to normal ESP operation and restore ESP switch functionality allowing for ESP ”Full”, “Partial”, or “Off” modes. |
Originally Posted by Ctimrun
(Post 315559)
mode, the ESP Telltale will be illuminated in the instrument cluster, and the vehicle odometer will display a “ESP OFF” message. |
Bump.....Anyone? Dash lights turn off when ESP is disabled after the TSB or with an 08 or do they stay on all the time?
| All times are GMT -8. The time now is 09:26 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
