Two top question...
Old Sep 26, 2010 | 12:21 PM
EagleArmsHBAR's Avatar
Default Two top question...
When the softtop and hardtop are both installed, is there any way to have the softtop raised up a bit so not to get in the way of the back gate and hardtop rear window?
Old Sep 26, 2010 | 12:32 PM
thrshr01's Avatar
Why not just remove the soft top? It's just 4 screws and it gives you so much more room.
Old Sep 26, 2010 | 12:34 PM
Ghost63's Avatar
Both tops are installed for shipping purposes only. You are supposed to remove one and run the other.
Old Sep 26, 2010 | 01:07 PM
rubi08unlimited's Avatar
I had no idea that they could both be on at once. is the back "glass" supposed to be removed when you take the soft top down? i remove the sides but have been leaving the back in.
Old Sep 26, 2010 | 03:08 PM
Kalamari's Avatar
Remove the soft top if your hard top is on.
I take the back window off of my soft top when it's down, but I'm anal about my Jeep.
Old Sep 26, 2010 | 03:21 PM
Enzo's Avatar
That is correct, read it when I took it home the first day. Jeep had labels on the soft top.Do not operate with soft top, transportation only
Old Sep 27, 2010 | 06:39 AM
Smopho's Avatar
I bought my Jeep as a Dealer Demo that had 180 miles on it. It had the dual top with the soft top installed inside the hard top. The corners of the soft top boot were worn through, and the soft top itself had a worn spot on each side and was damaged. The dealer ended up replacing the soft top.
