U1417?
Got this code for my left rear wheel speed sensor, found broken wire at sensor, repaired wire and put in new sensor for good measure, cleared code, was good for a day now light is back on and skid control still activates when first accelerating...any ideas?
Double check your wire repair, sensor installation.
Here is some more info from another forum:
U1417-IMPLAUSIBLE LEFT WHEEL DISTANCE SIGNAL RECEIVED
When Monitored:
Ignition on.
Set Condition:
The PCM gets an implausible signal over the CAN C circuit from the ABS Module. The circuit is continuously monitored. One Trip fault.
Possible Causes
VEHICLE SPEED SENSOR FAULT ACTIVE IN ANTI-LOCK BRAKE MODULE
CAN C BUS CIRCUIT SHORTED
CAN C BUS CIRCUIT OPEN
ABS MODULE
POWERTRAIN CONTROL MODULE (PCM)
When Monitored:
Ignition on.
Set Condition:
Possible Causes
ABS MODULE
