U1417?
Got this code for my left rear wheel speed sensor, found broken wire at sensor, repaired wire and put in new sensor for good measure, cleared code, was good for a day now light is back on and skid control still activates when first accelerating...any ideas?
Double check your wire repair, sensor installation.
Here is some more info from another forum: U1417-IMPLAUSIBLE LEFT WHEEL DISTANCE SIGNAL RECEIVED When Monitored: Ignition on. Set Condition: The PCM gets an implausible signal over the CAN C circuit from the ABS Module. The circuit is continuously monitored. One Trip fault. Possible Causes VEHICLE SPEED SENSOR FAULT ACTIVE IN ANTI-LOCK BRAKE MODULE CAN C BUS CIRCUIT SHORTED CAN C BUS CIRCUIT OPEN ABS MODULE POWERTRAIN CONTROL MODULE (PCM) |
Since I posted light has been off and on, at this time light is off and jeep is driving good...thank you for your service!
Originally Posted by BDAN1020
(Post 3387628)
| All times are GMT -8. The time now is 07:11 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
