warped clutch
Old May 23, 2010 | 05:49 AM
justinp.'s Avatar
Default warped clutch
Yesterday I was doing some yard work and needed to remove a small shrub. I figured rather than digging for an hour why not rip it out with a tree strap and the jeep. When I initially went to pull it in 4H the thing wouldnt budge. So i backed up and yanked it out with a running start. My question is if you think I warped my clutch when trying to pull it out as I smelled a slight burning after and when I drove it later in the day the starts in 1st gear when letting the clutch out were rough and shaky. Since driving it more its gotten better but I just want to see what others think of possible clutch warpage and a solution. If dragging a shrub out warps a clutch, what will happen when i take it crawling over rocks
Old May 23, 2010 | 06:33 AM
rmdchewie's Avatar
I've never heard of warping a clutch, a flywheel maybe but it would take a hell of a lot more than a shrub to do it. Interestingly enough, I just did that very same thing last weekend with my Jeep. Quite the versatile tool. Next time use 4 low.
Old May 23, 2010 | 12:20 PM
justinp.'s Avatar
thanks for the words of wisdom and advice. and yes the jeep is quite versatile
Old May 23, 2010 | 01:20 PM
JKHank's Avatar
How big was the shrub?! Unf todays vehicles aren't built like they used to be. (I feel so old saying that).
Old May 23, 2010 | 02:38 PM
justinp.'s Avatar
the shrub was about 4 ft in diameter. pretty small but the root system was pretty strong for the 3.8l and 3.21 gears to pull out
