JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Stock JK Tech (https://www.jk-forum.com/forums/stock-jk-tech-12/)
-   -   Water leak at rear wiper motor (https://www.jk-forum.com/forums/stock-jk-tech-12/water-leak-rear-wiper-motor-316590/)
07 Rescue Green 01-28-2015 07:19 PM
Has anyone else had this issue? What is the fix? It's leaking where the shaft goes through the window and runs down the inside of the window and door. Thanks.
baileyj 01-30-2015 02:41 AM
https://www.jk-forum.com/forums/stoc...r-leak-168978/
Check out this thread. Mine was doing the same thing.
ronjenx 01-30-2015 05:48 AM
I was thinking the OP is referring to rain water leaking in, not washer fluid.
07 Rescue Green 01-30-2015 02:24 PM
Yep, it's leaking when raining out, just enough to get the carpet wet. The leg on my speaker is rusty plus I can see it running down the window. Thanks.
Garrison Boone 01-20-2019 08:27 PM
​​​​​I know it's been a few years, have you found a solution for this?
Lisa Lyman 02-05-2019 02:42 PM
Leak
[QUOTE=07 Rescue Green;4046346]Has anyone else had this issue? What is the fix? It's leaking where the shaft goes through the window and runs down the inside of the window and door. Thanks.[/QUOTE
Hi I am having the same problem. What did you do?
Jay2013jk 02-10-2019 08:18 AM
This might be your solution...Checked using 2013JKU.. here is the mounting hardware kit with 2 gaskets for the rear wiper motor...68002492AA
MOUNTING HARDWARE, Rear Wiper Motor
ChryslerProbably about 30 bucks for the kit.
