Water leak at rear wiper motor
Has anyone else had this issue? What is the fix? It's leaking where the shaft goes through the window and runs down the inside of the window and door. Thanks.
https://www.jk-forum.com/forums/stoc...r-leak-168978/
Check out this thread. Mine was doing the same thing.
Yep, it's leaking when raining out, just enough to get the carpet wet. The leg on my speaker is rusty plus I can see it running down the window. Thanks.
Leak
[QUOTE=07 Rescue Green;4046346]Has anyone else had this issue? What is the fix? It's leaking where the shaft goes through the window and runs down the inside of the window and door. Thanks.[/QUOTE
Hi I am having the same problem. What did you do?
This might be your solution...Checked using 2013JKU.. here is the mounting hardware kit with 2 gaskets for the rear wiper motor...68002492AA
MOUNTING HARDWARE, Rear Wiper Motor
ChryslerProbably about 30 bucks for the kit.
