what do i need to do at MIN. to get 35'' tires to fit on my stock 4dr sahara.
Hello every one this is my first post. what do i need to do at MIN. to get 35x12.5x18' tires to fit on my stock 2010 4dr sahara? i have a set of quadratech spaces already if that enough?
Good luck
You have to cut your fenders or get flat ones to start.I am cutting mine in the spring. Then try and find spacers for your springs. That might work with a little rub.Good luck.
Assuming you are slim then 35s will fit on a stock JK if driving on road only AND only you driving.
As soon as this changes, ie more cargo, more passengers or off-road flex needed, 35s will rub on the rear metal tub (not on the fenders), in which case a 2.5" BB or coil lift is needed.
Good topic. I'm also new to modifications. Ideally what I'd like to do is get a little more ground clearance for off road without adversely affecting the on road performance and handling. I was thinking flat fenders, wheel spacers and larger tires. I have 245/75 R16 on there now. How much bigger can i go without a lift? I DO go off road, but nothing extreme like Rubicon or anything, just places cars can't go like old abandoned logging roads in the Adirondacks
as for cutting the fenders how whats the best way
i do have a set of used rubi fenders and front and rear bumpers that i can cut. Does any one have pictues or even a link where i can be able to get an idea what i have 2 do? I aslo hear bad things about body lifts whats the deal??
