What is this tube and is this a problem?
Hey everybody! After my first time out playing in the mud and on some trails last weekend I noticed that I had some sort of oil or lubricant splattered on the inside of my drivers side wheel well. I also noticed that this tube had fluid running almost all the way down it. My guess was that this is the diff breather and that I some how managed to overheat it which caused fluid to come out. Am I right? On Sunday I’m planning to go out to some sand dunes; will I need to look further into this before I use 4WD again? Am I just making a big deal out of nothing? I’m still new to Jeeps so I may be over-reacting but I don’t want to mess it up. Thanks for any help
Make breather tubes longer and you will have less chances of getting water or mud on the inside of your diff run the tubes up higher. If your tube is below the water line when you play you will contaminate your fluid . I ran my tubes up to a hight of 5 foot on my dodge ram i was in georgia and in the swamps a lot.
