What type of wheel is this?
Old Dec 11, 2010 | 03:59 PM
Eckman's Avatar
Default What type of wheel is this?
Does anyone know if this wheel is a true JK wheel? It is on a 2007 JK. DId they do away with this wheel after 2007? It is a 16" wheel. Buddy of mine is trying to figure out if a 265/75R16 tire will fit on this in regard to the rim width.
Thanks...
Old Dec 11, 2010 | 04:30 PM
KSARG1's Avatar
It is a stock Jeep wheel but I'm not sure of the width.
Old Dec 11, 2010 | 05:19 PM
remingtonJK's Avatar
I am running 285/75/16 on factory steel wheels. He should be fine.
Old Dec 11, 2010 | 07:32 PM
Ace09's Avatar
Nice jeep, u have any lift? Rubbing problems with the stock wheels? I've thought about the same size tires but am not sure, some people say one thing and some say another.
Old Dec 12, 2010 | 02:41 AM
Lorrel's Avatar
245 is the width of the tire in mm, so the 265 is 20mm or about 3/4" wider. It should be OK on the stock 16" wheel you posted, and will most likely hold a bit better when airing down.
Old Dec 12, 2010 | 03:56 AM
barnettd's Avatar
Default 265 is fine
I had those on my 2008... original wheels. I've since moved to 18" wheels. There are a lot of posts with guys running 265 + on those rims. It will look good.
Old Dec 12, 2010 | 04:56 AM
08JKRHD's Avatar
i don't think those are steel....
Old Dec 12, 2010 | 11:01 AM
Default 315/75/16
I say you will be fine. I have 315/75R16 Pro Comp Xtreme Terrains on mine and dont have any problems
Old Dec 17, 2010 | 09:10 AM
Orangeav's Avatar
Thanks...
I ran 285/75/16 on the this style stock 16x7's for a few weeks and didn't like the way they were contacting the road. I would say 265/75/16's will be fine otherwise I'd look to a wider wheel. Be sure to check the tire spec to see the recommended min-max rim width before you go much larger.
