Wheel spacers
Alright I have a stock 2013 jk, want to give it a lil more aggressive look, what do you guys think about 2 inch wheel spacers. It's cheaper than buying wider wheels and with the spacer shouldn't it allow me to a bigger tire as we'll. let me know what you guys think. Thanks .
edit, just looked they are out there.
I checked mine two times since I put them since you have to after the for 100 miles then every rotation, if installed correct you shouldn't have any issues
I've had mine on for 35K miles without issues. Wheeled hard occasionally, mostly moderate trails though. I check them when I rotate tires with the torque set a little lower than what I put them on at to not mess with loctite.
Mine are Spidertrax 1.5" and they have been great.
I've had mine on for 35K miles without issues. Wheeled hard occasionally, mostly moderate trails though. I check them when I rotate tires with the torque set a little lower than what I put them on at to not mess with loctite. Mine are Spidertrax 1.5" and they have been great.
