When to change transmission fluid
Just installed a transmission cooler and I was thinking of changing my fluid too, but when I checked, it looks brand new. I have 37,000 miles, should I wait and check again at 50,000 miles?
Originally Posted by horrocks007
(Post 3262340)
I'm sure someone else could throw out better guidance, but what I know is;
Are you hard on the vehicle like stop and go, drive through deep water, tow a lot in those 37k? If not it should be good till 50k. Honest question IMO, books aren't always realistic. |
Just changed mine at 40k. Was pleasantly surprized at how clean the bottom of the pan was and almost zero debris on the magnet.
Ordered an OEM filter, trans pan and magnet from an online Mopar parts vendor. The trans pan was only $8.95. Worth it to me, no cleaning of old pan, removing old RTV, etc. Just wipped down new pan with brake clean. Used Permatex "The Right Stuff" in a pressurized container when installing new pan. Filled back up with Mopar ATF+4. So to answer your question, if you don't use your Jeep for "police, taxi, fleet or frequent trailer towing", I'd wait until 50k. |
Thanks, I am gonna wait. I do some beach driving now and then and have a roof rack which adds weight. Over-all I am light in the skinny pedal. I just wanna be safe. Thus the trans-cooler too.
(Post 3262340)
Originally Posted by Sgt Mack
(Post 3262460)
I changed mine at 30k when I installed my trans cooler. It was dark and smelled slightly burned. The service manual will give you recommended mileages, but every vehicle is driven differently.
With something like transmission fluid, I don't see why anybody would go by the recommended mileage instead of the fluid condition. I didn't notice any difference in the transmission's performance, but I have the peace of mind that the fluid is new. I frequently tow with and wheel my Jeep (typically in deep sand) so why not give the transmission every advantage I can give it? |
Originally Posted by tmhd2
(Post 3264345)
With something like transmission fluid, I don't see why anybody would go by the recommended mileage instead of the fluid condition. |
Originally Posted by Jeff Loughlin
(Post 3265321)
x2 on this. Pull the dipstick and see what comes out.
I got a good idea. Why don't you guys list your recommendations. Let's see how well they compare to the people that spend millions of dollars on research and development. :rotflmao2: |
| All times are GMT -8. The time now is 11:27 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
