Where should I hammer?
I am replacing the u-joint in the front axle and I can’t even get to it. I need to separate the hub and bearing assembly from the steering knuckle. Cleveland winters on my 07 have taken a toll. It’s rust welded pretty good.
Where can I apply maximum force from the BFH without doing more damage than I already have?
Information from here & Stu Offroad was helpful and I’ve seen some videos of it sliding right out. But in my world not so much…
3 bolts and I’m free right? (13mm 12point). Well, once you get the caliper & rotor off anyway.
Just did my 2007......I actually had a gear puller in my tool box.....put tension on it.....tap.......out came the shaft!! I hit the whole shooting match with a wire brush and some oil before installing!!
