Differential Fluid Question
Old 06-21-2018, 07:39 AM
Ozzmann's Avatar
Default Differential Fluid Question
It is time to change the differential fluid on my 2016 Wrangler JK. I do a little bit of light towing with my ATV. My question is has anyone used Schaeffer Extreme performance Full Synthetic oil 75w-140 or Schaeffer Supreme Gear Lube 75w-90. Thanks for the replies.
Old 06-21-2018, 08:15 AM
Wuebben.2's Avatar
https://www.jk-forum.com/forums/show...=346842&page=2
Pretty much any gear oil is good for the diffs as long as it has an API GL-5 rating
Old 06-21-2018, 08:55 AM
rob_engineer's Avatar
I've towed a 5000 pound trailer quite a bit. Use any synthetic approved fluid and you'll be fine. I towed the first time when it had 5000 miles on it. I now have 103,000 trouble free miles.
Old 06-21-2018, 03:09 PM
Jay2013jk's Avatar
Default Diff Fluid
You should check the owners manual... I my memory is correct MOPAR Syn diff fluid is called for by Jeep. BTW.. that is what I put back in at 50,000 miles.
Old 06-21-2018, 03:15 PM
Wuebben.2's Avatar
Here's what's recommended for a 2017
jrcoffey (06-23-2018)
Quick Reply: Differential Fluid Question
