Will FCA warranty soft top deterioration?
I have 31K miles on my '15 JKU with soft top and a handful of issues with the soft top:
1. one of the frame parts in the rear is bent ever so slightly and has been since it was new 2. where the tailgate closes against the window fabric is gradually wearing the edge of the fabric 3. the stitching where the cable comes out, where the top folds when putting it in "sunrider" mode, is coming loose, one side is bad (1" or more of stiching gone) and the other side is starting to go. This comes from folding the top. It's just a poor design. 4. there is pervasive rust on the soft top frame. 5. don't even get me started about wear on the foam stuff that's supposed to keep it from leaking... Since it is such a royal PITA to work with the local dealer usually requiring a multi-day stay and no loaner vehicle, I'm loathe to take it in. But since the 36K mark is coming up, if they MIGHT warranty the top I think it would be worth it. So, any comment? Anyone know if the dealer is likely at all to warranty the top or would I be signing up for a big fight with FCA insisting that by putting the top up and down I am abusing it? [FWIW my Miata wore a hole in the soft top from folding it up and down every day and Mazda replaced it under warranty at about 35Kmi without question, then a few years later Mazda TSB'd that top issue; warranty on convertible top issues should be routine] |
I'm curious on this as well. Girlfriend has a 15 soft top and it's not as well built as others I've bought on CL and she's still under warranty.
I would be looking at what your bumper-to-bumper warranty looks like. My wife's 2016 is a 36 month, 36,000 mile warranty... I think?
yeah it's 36K bumper to bumper but they will attempt to exclude normal wear and tear. like for example, you wouldn't be able to warrantee the tires under this warranty, or the engine oil that came from the factory.
I'm concerned they are going to say any degradation of the top is normal wear and tear, not manufacturing (or design) defect. |
Originally Posted by mr72
(Post 4323291)
I'm concerned they are going to say any degradation of the top is normal wear and tear, not manufacturing (or design) defect. I'm not saying there's no chance at all.....I'm just betting it's a very slim chance. We're all rooting for you though! :wink: :cheers: |
I feel your best bets would be the following.
- Any leaks that are present, that can't be repaired without replacement of the top. You mentioned the foam, so that may be able to be repaired. - The rust problem, but they may repair that as well. Look up rust coverage in the warranty terms, it will be defined of the type of areas which are protected against rust. Rust protection is covered in the bumper to bumper. You need to focus on "actual" problems observed. For example, you mention the stitching coming apart, but is there an actual problem associated with that stitching coming out such as not being able to properly fold the top, or water leaks? Looks like a rag doll isn't an actual problem other than cosmetic. If you can identify enough of these actual problems, they will either repair them, or throw in the towel and say, "It will cost us less to replace than to repair." |
Originally Posted by Rednroll
(Post 4323728)
