Windsheild bracket rust.....and......
Old Sep 3, 2008 | 10:53 PM
Broncojohn's Avatar
Mine was built in June '08 and I drove it off the lot on Aug 5th, on the 9th I noticed the rust. The rust must be from the factory
Old Sep 4, 2008 | 04:52 AM
saltman's Avatar
At least yours came with all the bolts. Yes mine are rusting. This is the day I brought it home. Supposedly the Jeep had to be sent to a body shop to put the bolt in. The dealer says there was xtra metal in there from the factory that prevented them from being able to do it. Amazing build quality. Two others were missing on the cowl.
Old Sep 4, 2008 | 06:58 AM
IndianaJK's Avatar
I notice rust on mine right away. I took the brackets off and put some white lithium under it and on the bolts. I
I think I am going to get some plastic washers to put under the torx bolt heads to take away the metal to metal contact.
Old Sep 4, 2008 | 07:51 AM
Splash's Avatar
Odd. Mine already have plastic washers.
Old Sep 5, 2008 | 12:01 AM
TINMAN080's Avatar
Default boltheads not painted
These boltheads don't have paint on them, they have a light treatment almost like gunblue. Won't holdup forever. run the bolt out, punch a hole in a piece of cardboard, put the bolt into the hole, spray the bolthead flat black ENAMEL, reinstall and then touchup the torx pattern in the bolt head with a tornoff paper match as a ''brush''. Works good, looks good, lasts 2-3 years in a reasonable environment.
Old Sep 13, 2009 | 03:49 PM
CalebSC's Avatar
Default Rust
I have a rust ring under the torx bolts on the windsheild. I took two of them out. It appears that the plastic washer was torked down too tight and cracked the paint and that is where the rust located (counter sink ring) is coming from.One of the washers was missing half of its counter sink ring. I will see if the dealership can order replacement washers. I cleaned the rust out of one hole and applied rustolium paint with a small brush. I also hit the bolt itself with some paint. If anybody else has a similar problem or a better answer to this problem please let me know. I can't believe Jeep could not see this was going to be problem just like the steering stabilizer. WTH!!!!!
Old Sep 2, 2011 | 04:34 PM
Flharleycop's Avatar
Can you remove that whole plate and put some type or marine white grease under the plate to avoid future rust under it? Is it easy to take off the bracket plate?
Old Sep 5, 2011 | 02:57 PM
I took off my brackets today and found light surface rust and lots if dirt. I am going to clean it up an put a light grease on the lower part to reduce to potential for future rust.
ID:	207232   Click image for larger version
Old Sep 8, 2011 | 05:49 PM
Saw was an older thread any newer 11-12 have this besides mine?
Old Sep 10, 2011 | 12:36 PM
shoe1724's Avatar
I cut and contact cemented an old bike tube to the back of the mount and hit the news bolts with a few coats of rattle can before installing. been almost a year and no rust, still looks brand new.
