Windshield Washers Squirt Too High
They seem to only hit the top half of my windshield, anyone else? is there a way to adjust/lower the spray pattern?
Originally Posted by Mschneid
(Post 4015731)
I replaced the washer nozzle on my 2011 with a nozzle from the 2013+.
They do have two holes instead of just one. |
That's what she said
The nozzles are net. They are not adjustable.
My 2010 JKUS got bumped and the hood needing replacing. My insurance company graciously supplied the upgrade. The 2013+ dual nozzles really make a big difference, especially with mud. Where I once got a soft misting, now the washers are a dual deluge... with one on each side of the windshield, driver and passenger.
:beer: |
(Post 4015731)
Originally Posted by mwtrent
(Post 4016705)
Check them for blockage like scale buildup or wax. In the past I have even used a needle to clean them out as well as lift them up and push them down to adjust the spray.
Seems maybe the washer was designed to be used while driving at highway speeds. Or to spray the car behind you while you're stopped at a red light. |
Mine were the same way, even brand new when they were clean as could be.
I simply took a small flathead screw driver and pressed LIGHTLY in the hole where the fluid sprays out (toward the bottom side), making a very slight change in the hole opening. I mean very slight. Now it completely saturates my windshield with a quick squirt of the fluid. |
