Stock JL Tech Bulletin board forum regarding issues with OE (original equipment) components of the Jeep JL Wrangler (Rubicon, Sahara, Unlimited and X) such as factory suspension parts, engine, transmission, body parts, interior fixtures and the on-board computer.
2017 Jeep Wrangler Wont turn off
Old Sep 30, 2021 | 02:24 PM
BajaJK's Avatar
Exclamation 2017 Jeep Wrangler Wont turn off
Last Month, My 2017 Jeep wrangler did not start I tried to Jump start it and it worked. Took it to Autozone and changed the battery since the guy told me it was BAD (AC Delco). I changed it for the Duralast Platinum and it ran perfectly for about a month until last week it did not start again. So here is what happened: I went to my car pressed the unlock key in the remote and it worked fine the odometer and the jeep sign showed in my dash. I put in the key and crank it up but it turned everything off no more odometer and no more jeep sign. There was not a single volt of power in the car. I took my battery to AutoZone to check if everything was fine and it was in perfect shape with around 12.7 volts. I put back the battery and left the car disconnected for a couple of hours and connected back in and it worked fine. I took the car to the mechanic to check on the electrical and he mentioned everything was fine. The car has been running fine but I am scared that this happens again in the future. Has anyone had this trouble before?
Thank you,
Old Oct 2, 2021 | 01:10 PM
ghstrydr's Avatar
I would check your battery cable at the connectors. It is sometimes hard to spot when they start to corrode and loose connection.
Sorry, I quickly read your post, thought you had a starting problem.
