Can dealer add Anti-Spin Differential option
I have a 2013 JKU that came with the factory anti spin and I can assure you that the factory anti spin is not a Detroit Truetrac. The factory system is called Trac-Loc Anti-Spin. It has spider gears as well as clutch packs.
correct. Trac-loc works well but there are a lot of complaints of chipped/broken spiders gears.
yes it’s redesigned and different supposedly stronger.... as I stated before The actual axle tube is thicker metal. And regardless which trim the tube itself is shared regardless of rubicon or a sport. Just the axle tube.... I’m trying to be smart not sure we need a rubi..... they are willing to work on the price with this truck as a left over 18 .... it drove very well didn’t feel any weird steering issue and it’s already got a mopar lift with 35s on it and they agreed to regear it so that it shifts to 8th gear
If they are regearing then just have them also install truetracs since they are already messing with the gears and carrier.
As far as the Factory anti spin I would not waste the time effort or money unless you ordered it from the factory that way.
Mine had 56000 Miles on it with mostly highway and very little offroad and the clutches were worn out and gears all chipped up.
Are they regearing the differentials or just programming the correct tire size?
I just skimmed this thread, and I know you are concerned about warranty and keeping it more stock, but I'd argue you're better off after market for both quality of parts and cost of labor. Either that or keep it as is. LSD in my opinion is only worth it if 1) came like that, and 2) you have no intention of changing it. If you like the jeep and the budget aligns, buy it as is. I'd bet you don't notice it missing the LSD much. $600+ towards something you will notice more. Also, they now know it's not what you really want. That's just more leverage for you.
