Stock JL Tech Bulletin board forum regarding issues with OE (original equipment) components of the Jeep JL Wrangler (Rubicon, Sahara, Unlimited and X) such as factory suspension parts, engine, transmission, body parts, interior fixtures and the on-board computer.
Frame Corrosion Protection
Old Sep 21, 2022 | 05:10 PM
BlackForkTool's Avatar
Former Vendor
Default Frame Corrosion Protection
Winter is coming! Protect your Jeep frame from internal frame corrosion.
Jeep Wrangler frames are commonly known to corrode from the inside. Large holes in the chassis designed to access other frame attachments also allow mud, salt and water into the the frame. Once inside the frame, debris does not simply "flush" or "blow" away, it promotes corrosion........Keep it Out! Our frame plugs cover the large holes located directly behind the tires while leaving the drain holes open. Removal for cleaning and maintenance is easy, and reinstallation requires no tools.
