Windshield light bars
I really want to get a windshield light bar for the JK but I've been looking around and I don't see a single Canadian rig with that kind of light bar... is there a reason for this or am I just imagining things?
I wouldn't fit in the garage if I had one!!
There's a guy in Winnipeg with one, but I don't think he is on the forum. I've tried to get him to stop and talk but he looked at me like I was a crazy man. Oh well.
Awesome pics! I've been looking at the RR at Northridge4X4 and the MBRP at Q-tec! Reason I asked is that I heard something about it being illegal to have lights above the windshield... anyone else heard anything like this? Also, once I get the bar what else am I gonna need? Lights of course, but will I need wiring kits or brackets or does all that stuff come with the lights?
one word of advice about those light bars. i'm not sure what your trails are like in AB, but if they are anything like the trails I've wheeled in BC/ONT/QUE with lots of trees and tight trails those lights will be knocked off or wrecked so quickly on a lightbar like that which mounts them up high and without protection. That being the reason I designed mine how I did.
I would assume that you would have to buy a wiring kit if they offer one, or come up with your own harness to wire everything up. and brackets should come mounted on the bar.
Guest
Posts: n/a
not illegal. if I remember right its illegal to have lights that arn't covered above the headlights, so you need light guard things...but I've never heard of anyone getting in trouble for that...and no ones every said anything to me.
As for the wiring most lights can be purchased in a pair and will come with a wiring harness that includes relay,switch and wire to run the lights. You may have to add a little extra wire to the centre lights but you they usually come with lots of wire. Atleast the IPF and Vision X lights do for sure. These lights also come with covers and have a grille guard that you could also purchase if you wanted to protect them when offroad.
If you have any others questions please feel free to PM me
EXCERPTS FROM THE BC MVA REGS:
Auxiliary driving lamps
4.09 (1) A motor vehicle may be equipped with 2 auxiliary driving lamps, mounted on the front of the vehicle at a height of not less than 40 cm and not more than 1.06 m, that are capable of displaying onlywhite light.
(2) An auxiliary driving lamp must be directed so that the high intensity portion of the beam is, at a distance of 8 m from the lamp, at least 12 cm below the height of the lamp and, at a distance of 25 m from the lamp, not higher than 1.06 m from the road surface.
(3) An auxiliary driving lamp must operate so that it is illuminated only when the upper beam of a multiple beam headlamp is illuminated.
[en. B.C. Reg. 476/98, s. 2.]
Fog lamps
4.11 (1) A motor vehicle may be equipped with 2 fog lamps, mounted on the front of the vehicle below the headlamps, that are capable of displaying only white or amber light.
(2) Each fog lamp must be
(a) mounted not more than 30 cm below the headlamps, and
(b) adjusted and aimed so that, at a distance of 8 m from the lamp, the centre of the beam is at least 10 cm below the height of the fog lamp.
(3) The fog lamp wiring and switch must permit simultaneous operation of the parking lamps, tail lamps, licence plate lamp and, if required, clearance lamps.
(4) The operator of a vehicle may use fog lamps instead of headlamps when atmospheric conditions make the use of headlamps disadvantageous.
Any additional lighting that does not fall into either of these categories would be for off highway use only. An astute traffic cop may consider your light bar to be "Unauthorized Lighing" and COULD net you a $109 fine. (DOES NOT INCLUDE MARKER, SIGNAL OR PARKING LIGHTS)
Fog lamps
