2016 Jeep JK Wrangler Phase One Build 75th Anniversary "Bronze Tanner"
10 Attachment(s)
2016 JEEP JK WRANGLER PHASE ONE BUILD 75TH ANNIVERSARY BRONZE TANNER
Axles: DANA 60 FRONT ROCK JOCK VXR AXLE - CURRIE ENTERPRISES - ARB AIR LOCKER - CUSTOM WIDTH FOR 37 INCH TIRES - F450 KNUCKLES - HEAVY DUTY TIE ROD - 5:38 GEARS - MASTER INSTALL KIT W/ BEARINGS - ALL BRACKETS INCLUDED - 1350 YOKES - 6 ON 5.5 BOLT PATTERN - DIFFERENTIAL COVER DANA 70 REAR ROCK JOCK AXLE - ARB AIR LOCKER - CUSTOM WIDTH FOR 37 INCH TIRES - FULL FLOAT - 5:38 GEARS - ARB LOCKER -40 SPLINE -1350 YOKE -6 ON 5.5 BOLT PATTERN -DIFFERENTIAL COVER Air Compressor: ARB AIR LOCKER MANIFOLD KIT ARB INFLATION ACCESSORY KIT ARB TWIN AIR COMPRESSOR MORE OFFROAD ARB TWIN AIR COMPRESSOR MOUNT AEV PRO CAL Driveshafts: FRONT JE REEL 1350 CUSTOM DRIVESHAFT REAR JE REEL 1350 CUSTOM DRIVESHAFT Suspension: CURRIE ENTERPRISES ANTIROCK ALUMINUM FRONT SWAY BAR KIT CURRIE ENTERPRISES ANTIROCK ALUMINUM REAR SWAY BAR KIT RECON FRONT BOLT-ON HYDRAULIC BUMP STOP MOUNTS (PAIR) RECON FRONT COILOVER MOUNTS FOR 12" 2.0 / 2.5 COILOVERS RECON KING AIR BUMPSTOP 2.0 4" (LIMITED TO 2") - BLACK FINISH RECON KING COILOVER 2.5 12" REBEL SPEC RECON KING COILOVER 2.5 14" REBEL SPEC (REAR ONLY) RECON KING COILOVER COMPRESSION ADJUSTER 2.5 (EACH) RECON KING COILOVER INTERNAL BYPASS (2.5 ONLY) (EACH) RECON REAR BOLT-ON 14" COILOVER MOUNTS RECON REAR WELD IN BUMPSTOP MOUNTS REBEL OFF ROAD EXCLUSIVE TERAFLEX LONG ARM UPGRADE FOR RECON COILOVER CONVERSION Brakes: REBEL OFFROAD-RESTRAINT COMPLETE BRAKE KIT (DANA 60 AND 70) KIT INCLUDES: - 2x RESTRAINT FRONT ROTORS (DOUBLE DRILLED & SLOTTED) - 2x RESTRAINT REAR ROTORS (DOUBLE DRILLED & SLOTTED) - 1 SET OF FRONT PADS - 1 SET OF REAR PADS Bumpers: POISON SPYDER ROCKBRAWLER II REAR BUMPER WITH TIRE CARRIER RIGID D SERIES PRO FLOOD DIFFUSED Wheels and Tires: METHOD RACE WHEELS - 101 BEADLOCK TOYO OPEN COUNTRY M/T 37X13.50R17 Exhaust: BORLA CLIMBER CAT BACK EXHAUST SYSTEM Hood: DV8 HOOD – Paint Matched Shifter: B&M Short Throw Shifter Seat Recline Kit J.W. SPEAKER LED JEEP TURN SIGNALS MODEL 239 J2 SERIES Custom Race Roll Cage Attachment 678501 Attachment 678502 Attachment 678503 Attachment 678504 Attachment 678505 Attachment 678506 Attachment 678507 Attachment 678508 Attachment 678509 Attachment 678510 |
10 Attachment(s)
10 Attachment(s)
10 Attachment(s)
10 Attachment(s)
10 Attachment(s)
7 Attachment(s)
5 Attachment(s)
2016 Jeep JK Wrangler Build 75th Anniversary "Bronze Tanner" - PHASE TWO
Bronze Tanner came back for some more upgrades and goodies!
Artec Inudstries Nighthawk JKU Sliders - CT Bronze Powdercoated Poison Spyder Bruiser Bumper - CT Bronze Powdercoated KC Hilites G34 LED Pair Warn Industries Zeon Platinum 12000lb Winch Warn Spydura Synthetic Line Poison Spyder Aluminum Hawse Winch Fairlead - Mojave Sand Painted RockHard 4x4 Bolt-in Sport Cage w/ rear center cross bar - Mojave Sand Painted Alcon D60 Big Brake Kit PSC Steering JK Ram Assist Steering Kit 3/4 D Rings w/ Daystar D Ring Isolators Factor 55 Red Pro Link Loaded https://cimg4.ibsrv.net/gimg/www.jk-...92cae2aced.jpg https://cimg8.ibsrv.net/gimg/www.jk-...206a87a020.jpg https://cimg1.ibsrv.net/gimg/www.jk-...3096e0a2bd.jpg https://cimg9.ibsrv.net/gimg/www.jk-...56a7d41911.jpg https://cimg6.ibsrv.net/gimg/www.jk-...e1867b14e7.jpg https://cimg2.ibsrv.net/gimg/www.jk-...115999c5ac.jpg https://cimg5.ibsrv.net/gimg/www.jk-...1c27e855e4.jpg https://cimg7.ibsrv.net/gimg/www.jk-...3fc9a796f1.jpg https://cimg8.ibsrv.net/gimg/www.jk-...755df14b84.jpg https://cimg3.ibsrv.net/gimg/www.jk-...9968c05f9b.jpg |
