Katacon Built By Rebel Off Road
Former Vendor
REBEL OFF ROAD EXCLUSIVE TERAFLEX LONG ARM UPGRADE FOR RECON COILOVER CONVERSION
RECON FRONT COILOVER MOUNTS FOR 12" 2.0 / 2.5 COILOVERS
RECON FRONT BOLT-ON HYDRAULIC BUMP STOP MOUNTS (PAIR)
RECON KING COILOVER 2.5 12" REBEL SPEC
RECON KING COILOVER COMPRESSION ADJUSTER 2.5 (EACH)
RECON KING AIR BUMPSTOP 2.0 4" (LIMITED TO 2")
RECON KING COILOVER 2.5 14" REBEL SPEC (REAR ONLY)
RECON KING COILOVER COMPRESSION ADJUSTER 2.5 REAR
DANA 60 FRONT ROCK JOCK AXLE - CURRIE
- ARB AIR LOCKER
- CUSTOM WIDTH FOR 40 INCH TIRES
- F450 KNUCKLES
- HEAVY DUTY TIE ROD
- 5:38 GEARS
- MASTER INSTALL KIT W/ BEARINGS
- ALL BRACKETS INCLUDED
- 1350 YOKES
- 6 ON 5.5 BOLT PATTERN
- DIFFERENTIAL COVER
DANA 70 REAR ROCK JOCK AXLE - CURRIE (FULL FLOATER)
- CUSTOM WITH FOR 40 INCH TIRES
- HUBS / YOKE / DRIVE FLANGES
- 35 SPLINE AXLES (SUPER HEAVY DUTY)
- ARB AIR LOCKER (35 SPLINE)
- 5:38 GEARS
- MASTER BEARING KIT
- BRACKETS (UPPER/ LOWER CONTROL ARMS)
- BRACKETS (TRACK BAR ETC.)
-1350 YOKES
ARB AIR COMPRESSOR FOR LOCKERS
JEREEL FRONT AND REAR 1350 DRIVESHAFTS
REBEL OFFROAD-RESTRAINT COMPLETE BRAKE KIT (DANA 60)
KIT INCLUDES:
- 2x RESTRAINT FRONT ROTORS (DOUBLE DRILLED & SLOTTED)
- 2x RESTRAINT REAR ROTORS (DOUBLE DRILLED & SLOTTED)
- 1 SET OF FRONT PADS
- 1 SET OF REAR PADS
RACELINE RT231-AL BEADLOCK WHEEL
NITTO TRAIL GRAPPLER - 40X13.50X17
AEV PROCAL
POISON SPYDER BRAWLER LITE FRONT BUMPER
-BRAWLER BAR
-PLATE GUSSETS
-SHACKLE TABS
POISON SPYDER BRAWLER LITE LOWER SKID
POISON SPYDER WINCH FAIRLEAD MOUNT
POISON SPYDER FAIRLEAD LIGHT MOUNT
POISON SPYDER HAWSE FAIRLEAD
POISON SPYDER EVAP SKID
WARN POWERPLANT 9.5
WARN SPYDURA WINCH LINE
FACTOR 55 PROLINK
RIGID INDUSTRIES 10" SR-SERIES LIGHT BAR
POISON SPYDER FRONT AND REAR FENDER FLARES
POISON SPYDER INNER FENDER KIT
ROCKSLIDE ENGINEERING STEP SLIDERS
-WITH BODY ARMOR
-WITH LIGHT KIT
POISON SPYDER ROCKBRAWLER II REAR BUMPER
-WITH TIRE CARRIER
TERAFLEX STEERING STABILIZER
POISON SPYDER BACK UP LIGHTS
KC HILITES HEADLIGHT PACKAGE
BORLA Y-PIPE/CATBACK EXHAUST SYSTEM
Rebel Off Road
www.facebook.com/rebeloffroadllc
wwww.instagram.com/rebeloffroad
