Jeep TJ & YJ Wrangler Overall Jeep TJ & YJ Wrangler technical discussion bulletin board forum. This includes all Jeep Wranglers made between 1987-2006 and includes models such as the Unlimited, Rubicon, Sahara, Sport and X.
Weird problem help
Old 02-22-2017, 07:44 PM
JKRescue08's Avatar
Default Weird problem help
Hey all, got my first TJ, 2001 with 4.0 and noticed it was making an exhaust leak sound and clattering when I pressed the gas. I decided to do a tune up and put autolite app985 plugs, new coil, new springs/boots. I put it back together and the clattering noise was gone and it ran smoother than ever!
Next morning, I go to work and it's back to running the same old way. No pick up and weird noises. I got back from work, disconnected the battery for 20 minutes and put it back on. All of sudden it ran great and smooth again.
What could be the issue if, when I pull the negative cable and reconnect - it runs great? I have to pull the cable every day for it to run good.
I'm lost!
Thanks ya'll.
Old 03-05-2017, 10:04 AM
Navy-Jeepster's Avatar
Do you have a check engine light (CEL) on?
If you do, do you have a code reader?
Todd
Quick Reply: Weird problem help
