Dual Band (VHF/UHF) HAM Radio Install
honesty I know very little about ham Radios , etc. supposedly they have pre set frequencies/ channels that don't require a license. Hmm, with that said a couple of the organizers in the jeep club are in the process of setting up group testing for us so anyone running these radios will be legal...
These VHF/UHF radios primarily use the business frequency spectrum in the VHF range.
The Rugged Radios also have GMRS channels pre-loaded along with most of the team channels from Baja or KOH.
The business license gives a business the usage of that frequency in their area and no place else.
You can search the FCC site for frequency usage by a business in your area.
As a club you could get a frequency for your area that you plan to use the radios.
Todd
Todd
I nice thing about Ham (amateur radio) dual band radios is that there are NO preset frequencies. You can choose frequencies anywhere in the 2 meter / 70 cm bands. You can also use repeaters (which are free) which greatly increases your range. The technician level license is easy and worth getting. You will for like $15, be given a license good for 10 years and call sign unique anywhere in the world. It's worth the time investment. The test is not difficult and well worth it. There are very good dual band handhelds you can get on amazon for $48.
2 Meter Band Plan
2 Meters (144-148 MHz)
144.00-144.05 EME (CW)
144.05-144.10 General CW and weak signals
144.10-144.20 EME and weak-signal SSB
144.200 National calling frequency
144.200-144.275 General SSB operation
144.275-144.300 Propagation beacons
144.30-144.50 New OSCAR subband
144.50-144.60 Linear translator inputs
144.60-144.90 FM repeater inputs
144.90-145.10 Weak signal and FM simplex (145.01,03,05,07,09 are widely used for packet)
145.10-145.20 Linear translator outputs
145.20-145.50 FM repeater outputs
145.50-145.80 Miscellaneous and experimental modes
145.80-146.00 OSCAR subband
146.01-146.37 Repeater inputs
146.40-146.58 Simplex
146.52 National Simplex Calling Frequency
146.61-146.97 Repeater outputs
147.00-147.39 Repeater outputs
147.42-147.57 Simplex
147.60-147.99 Repeater inputs
70CM Band Plan
70 Centimeters (420-450 MHz)
420.00-426.00 ATV repeater or simplex with 421.25 MHz video carrier control links and experimental
426.00-432.00 ATV simplex with 427.250-MHz video carrier frequency
432.00-432.07 EME (Earth-Moon-Earth)
432.07-432.10 Weak-signal CW
432.10 70-cm calling frequency
432.10-432.30 Mixed-mode and weak-signal work
432.30-432.40 Propagation beacons
432.40-433.00 Mixed-mode and weak-signal work
433.00-435.00 Auxiliary/repeater links
435.00-438.00 Satellite only (internationally)
438.00-444.00 ATV repeater input with 439.250-MHz video carrier frequency and repeater links
442.00-445.00 Repeater inputs and outputs (local option)
445.00-447.00 Shared by auxiliary and control links, repeaters and simplex (local option)
446.00 National simplex frequency
447.00-450.00 Repeater inputs and outputs (local option)
You actually just can't pick any frequency you want in 2M/70cm, the FCC has a band plan that you need to adhere by. 2 Meter Band Plan 2 Meters (144-148 MHz) 144.00-144.05 EME (CW) 144.05-144.10 General CW and weak signals 144.10-144.20 EME and weak-signal SSB 144.200 National calling frequency 144.200-144.275 General SSB operation 144.275-144.300 Propagation beacons 144.30-144.50 New OSCAR subband 144.50-144.60 Linear translator inputs 144.60-144.90 FM repeater inputs 144.90-145.10 Weak signal and FM simplex (145.01,03,05,07,09 are widely used for packet) 145.10-145.20 Linear translator outputs 145.20-145.50 FM repeater outputs 145.50-145.80 Miscellaneous and experimental modes 145.80-146.00 OSCAR subband 146.01-146.37 Repeater inputs 146.40-146.58 Simplex 146.52 National Simplex Calling Frequency 146.61-146.97 Repeater outputs 147.00-147.39 Repeater outputs 147.42-147.57 Simplex 147.60-147.99 Repeater inputs 70CM Band Plan 70 Centimeters (420-450 MHz) 420.00-426.00 ATV repeater or simplex with 421.25 MHz video carrier control links and experimental 426.00-432.00 ATV simplex with 427.250-MHz video carrier frequency 432.00-432.07 EME (Earth-Moon-Earth) 432.07-432.10 Weak-signal CW 432.10 70-cm calling frequency 432.10-432.30 Mixed-mode and weak-signal work 432.30-432.40 Propagation beacons 432.40-433.00 Mixed-mode and weak-signal work 433.00-435.00 Auxiliary/repeater links 435.00-438.00 Satellite only (internationally) 438.00-444.00 ATV repeater input with 439.250-MHz video carrier frequency and repeater links 442.00-445.00 Repeater inputs and outputs (local option) 445.00-447.00 Shared by auxiliary and control links, repeaters and simplex (local option) 446.00 National simplex frequency 447.00-450.00 Repeater inputs and outputs (local option)
